Power steering issue
I just went out for a noce drive in the desert and the power steering went out, it has zero assist at idle and then it starts working again when you bump up the RPM's.
WTF??
WTF??
I had the same problem at about 4k when i went out for an easy day on the trails. took it back the the dealership and they replaced the pump. Now im at 9k and last weekend the same thing happened. Anyone have any idea whats goin on?? im gonna have to take it to the dealer again
P.S. this will be my second ps :pump and i have had the throw out bearing fixed twice and it is making noise AGAIN...
I started to get the same problem after muddin. Nothing then it kicks in. Thought cleaning under the hood "fixed" it, but its starting again. My main concern is that its lifted and the 35" Toyo tires are really heavy. If it gets worse I'll take it in, but doubt the dealer is going to cover it.
So I took it in to the dealership. They checked with Chrysler and Chrysler decided that since I have a 2 in buget boost lift and 33 in tires they have to VIOD MY WARANTY!!!!!!!! WTF!!!!!!!!?????? they told the service department that the waranty on the entire vehicle is VIOD!
So when I bought the Jeep I went to the service department and talked with the service manager, I asked him at that time about lifting the vehicle. He told me then that if I only lift it 2 in then everything will be fine and there will be no waranty isues. But now I am screwed if something else breaks.
So now I get to call Chysler and try and get someone that acctually knows about mechanical things on the phone and get a good explaation as to how my 2 in lift made the power steering pump go out.
Sort of sounds like the dealers are f...ked in the head when it comes to geometrical mods but also a good reason to wait till the warrantee is up before going about installing them.
No problems=no worries
Problems=?
Problems=?
I had this happen when i went to canada and did some trail riding... it was the power steering pump that crapped out. Went to a jeep dealer, spend like 200 bucks, and submitted everything to chrysler america when i got home, took months to get reimbursed. But it was covered under warranty. Take it to your dealer and they'll fix it for you. good luck
Might cost him more to fight for the right than it's worth by the time they drag it all out.
They're already pulling the mods thing on him and he hasn't even started.
It's a pretty cheap repair for a good mechanic.
