Problem with 4x4 shifter
Old Sep 5, 2011 | 02:59 PM
jman1208's Avatar
Default Problem with 4x4 shifter
Inside the jeep under the console there is a cable that connect to the shifter (4x4 shifter not manual) and theres a plastic cap that keeps the cable from falling off the shifter, does anyone know what that plastic piece is called i can't find anything about it i want to buy a replacement.
Old Sep 5, 2011 | 03:06 PM
arasco85's Avatar
Search 4x4 linkage. On my phone so I can't do the searching on here for you.
Old Sep 5, 2011 | 03:10 PM
ssease's Avatar
Check out this thread https://www.jk-forum.com/forums/show...r+case+zip+tie I think it is post #7 with the clip part number
Old Sep 6, 2011 | 02:14 PM
orig93gt's Avatar
I just had that damn little piece let go on me while out on the beach. Here is the part #68064273AA. Its only 30 cents so you may want to grab a few extras. I had to order them so i only have 2x4 until the piece comes in. advance adapters makes an upgraded cable kit that from the looks of it is near impossible to break. I am thinking about ordering the kit, but I wanted to hear from someone that has already used one. Good luck to you. Mine went at 10k miles, so its just a matter of time until it goes again i'm sure.
Old Sep 6, 2011 | 02:47 PM
Battlefrog's Avatar
Hope this helps....https://www.jk-forum.com/forums/show...linkage-repair
Old Sep 8, 2011 | 10:59 AM
largo's Avatar
I had a machine shop make me a entire arm out of billet steel and it has a larger knob coming off it and it attaches with a prelubed bushing and d clip. Works like a charm and got rid of the cheap plastic crap.
Old Sep 23, 2011 | 05:52 AM
orig93gt's Avatar
check out the install/write-up i did on one of the advancer adapters cable upgrade kits. https://www.jk-forum.com/forums/show...vance+adapters
