pull pal
I think a quality fluke style boat anchor would work as long as it was big enough and you burried it well. Only downside is they are fairly heavy and take up some space but if you have no other option I think it would be fine.
Well, digging the hole to bury the spare can take a LONG time. The Pull-Pal digs its own hole. It is not something I would routinely carry with me for the terrain here, but in sand dunes and sandy desert conditions, the Pull-Pal would be standard equipment for me.
I have a marine anchor that I use - it's called a "sting ray"
It's made of flat plate about 5/16th thick in three pieces
sorry no pics - but if you imagine a large filled in W with two curved pieces that slot into it ti create a pull point and to give the base plate a 30deg angle so that when you pull on it it submarines into the ground
when it's apart it packs flat
Ado
Ado
i was thinkinking if a self-digging boat anchor would work? or a farm plow spade welded with some 1/2 3/4 flat stock
( would it dig to deep? )
