Putting in a winch this weekend...Do I have everything I need?
So I'm putting in a winch this weekend.
The winch is a Warn VR8000 new in box and it's destined to live in an AEV tubeless front bumper for which I've already bought the winch mounting plate. I'm assuming that's all I need in terms of parts and hardware? Am I missing anything?
Then, there are related questions:
1) I'm using the stock Jeep/Mopar battery with the winch. Will this be an issue, short or long term?
2) The winch and mounting plate weigh a ton. The Jeep has a suspension lift already, which leveled out the stock rake. Now that there's the equivalent of a cow laying on the front end, is it common to add spacers to compensate for the extra weight/dip of the hardware up front? If so, what would everyone recommend? (the existing lift is a 2.5" AEV Dualsport).
Thanks in advance...
1.) I run my warn XD9000i on stock battery with no problems
2.) A lot of ppl add 3/4" coil spacers to make up for suspension sag. I have a set of them on top of my 4"lift
I went to West Marine and made up longer power cables so o could route them properly and not through the grill. They have the cable and ends with a bench crimper to properly install the connectors.
First, remove your fog lights, bracket and all. If you don't you'll bend the shit out of them due to a hidden lip on the front frame rails when pulling off the bumper.
If you've got a '12 you will fight the vacuum pump relocation bracket. I'd advise to drill the holes 3/8" further forward on the winch plate before you start your installation (so the pump is resting hard against the AEV plate rather than the trans cooler). My vacuum pump hose connection was stuffed into my trans cooler so hard that the winch plate wouldn't fit. I had to bend the cooler tube lines down underneath the trans cooler about 1.5" to get the vacuum pump to fit. I also removed that cooler line plastic bracket from the frame. Here are some quick pictures, I haven't had time to edit them yet.
Also if you bought a winch cover, it won't fit unless you push the winch towards the back of the Jeep, then to the driver side. I also upgraded the winch mounting bolts (1.25"x3/8") to grade 8 at this time.
Another item they don't tell you about is that you should spool a few wraps of line before you install the bumper. Fish the rest of your line through your fair lead and finish spooling once the bumper installation is complete.
Last, the AEV skid plate is attached to the bumper with cheap self tapping bolts. I snapped off two heads during the initial install. I recommend replacing all six with grade 8, 1"x3/8" bolts. Just don't go overkill when tightening them.
In the end I was pretty pissed at AEV. The amount of fighting I did and the price I paid did not add up. My PSC bumper, EVO Protek Skids, TF BB, even Nitro sleeves installed flawlessly compared to this expensive a$$ bumper.
To the OP, sorry I can't help you out as I'm waiting on my winch to be shipped and don't have it yet.
But to others, I'm curious if anyone has experience putting a Superwinch Tigershark 9500 into an AEV gen 1 bumper. My fear is that the right (passenger) side won't clear the winch motor.
Thanks for the replies. Unfortunately, with the awesome weather here in Washington, I had to make the tough decision to spend Saturday/Sunday outside working on the house, or in the garage working on the Jeep. I've been doing some house projects that are a "race to the finish" as far as weather is concerned, so the house got my time. There's a winch and boxes full of parts sitting under the front bumper. Maybe this week if I'm feeling adventurous.
It also occurred to me that I'll be police-bait without a front license plate, since I'll actually have a fairlead there. I ordered the AEV license bracket thingy which is on its way. The state patrol and even municipal police are pretty ticklish about license plates unfortunately.
