Question. Will a slightly larger tire give me a slight boost in mileage?
Old May 17, 2010 | 08:59 AM
spartan99's Avatar
Default Question. Will a slightly larger tire give me a slight boost in mileage?
Stock 3.73 auto JKU X. I'm thinking that a larger tire would allows the rpm's to spin at a lower rpm, right? Thus, wouldn't that give me better mileage? But, a larger tire means less torque at the wheels, which hurt mileage, right? Hmmm...
Just wondering what a slightly larger tire would do. Thoughts?
Old May 17, 2010 | 09:12 AM
MOJEEP's Avatar
It's always been the opposite for me. Larger tires = less MPG. I see your logic and understand that your not wanting to go much bigger but again I have never had luck with this.
Old May 17, 2010 | 09:16 AM
spartan99's Avatar
Yeah that's what I figured. The loss in turque outweighs the gear ratios.
Old May 17, 2010 | 09:22 AM
RevyJKU08's Avatar
Also, bigger tires usually weigh more as well. so loss of MPG again.
Old May 17, 2010 | 09:24 AM
AK4Dave's Avatar
Exactly, more weight, less mpgs. Now if you could find a larger tire that weighs less, things might be different....hard to say.
Old May 17, 2010 | 09:40 AM
robin's Avatar
I wouldn't think so........
Old May 17, 2010 | 09:48 AM
GoodysGotaCuda's Avatar
You are walking the line between engine load and rpm. lower rpm doesnt mean thats where the engine is most efficicent and may require more fuel to hold the same rpm. extra rotating mass doesnt help either.
