Question for you carpet-less JKs
Old Jun 4, 2014 | 04:32 PM
TitanOffRoad's Avatar
Default Question for you carpet-less JKs
Removed the carpet and bed lined my interior of the 2dr JK today. Found these two large holes covered with cheap tape from the factory. Curious as to what you guys have done to cover these holes and what they may be there for?
One on each side near the front seats.
Sent from my XT1055 using Tapatalk
Old Jun 4, 2014 | 05:13 PM
manniefreshJK's Avatar
Just curious of what did you use to line it with? Did you have to take?
Old Jun 4, 2014 | 05:33 PM
WINGIT's Avatar
I had mine professionally done. I had them spray into the holes so at least they were black. They can be good for storing things.
Old Jun 4, 2014 | 05:36 PM
TheDirtman's Avatar
Mine is filled with foam and did not do anything with it.
Old Jun 4, 2014 | 05:39 PM
dhughes's Avatar
Filled mine with foam and cut a ovalish piece of 16g sheet metal and epoxied them over the holes. After doing the bedliner you can't even see them.
Sent from my GT-P5113 using Tapatalk
Old Jun 4, 2014 | 06:23 PM
I used hurculiner and rolled it on after sanding everything down. Still not finished as I want a thick coating.
I'm thinking I may measure it and figure out a way to install a set of led lights. Maybe make a dim interior running light or something then.
Old Jun 4, 2014 | 06:55 PM
gunut's Avatar
There was a thread on here a while back that talked about this. I believe someone posted that you can by some rubber plugs that will fit these holes.
