Rattle
Old Aug 8, 2008 | 07:15 PM
AK4Dave's Avatar
Default Rattle
I have a bad rattle inside the door so tomorrow I plan on taking off the panel to see if I can find it. I see the one torx screw at the lock, and the 2 phillips in the door pull, and the rest of the panel is held on with those pop off pins. But, (and I just glanced at it so didn't look real close yet), how does the window roller handle come off? If you pry at it will it just pop off?
Thanks.....
Old Aug 9, 2008 | 07:00 AM
cmpmacchia's Avatar
Do a search...you'll find the solution. It has something to do with your door strikes.
Old Aug 9, 2008 | 11:10 AM
AK4Dave's Avatar
Well I found the info I wanted....I should have listed this differently, as although I need to find, and fix the rattle, I was mainly wondering how to get the window handle off so I can do that. Search revealed that "using a window handle tool" remove the "clips" holding the handle on. I hadn't taken the time yet to push the panel in far enough to see them.
Thanks....
