Removing the doors
Old May 2, 2008 | 04:43 PM
michiganjeep2008's Avatar
Default Removing the doors
In my 08 manual for removing the doors I need a #T50 Torx head driver - what is this?
Old May 2, 2008 | 04:51 PM
zoomzoomjr's Avatar
It is a star looking tool, that is available at your local hardware store that has forms like a screw driver, a ratchet attatchment, or maybe even a bit.
Old May 2, 2008 | 04:52 PM
easttnruby's Avatar
http://www.quadratec.com/products/98002_01.htm
Here you go!
pacer89's Avatar
At the bottom of the door hinge there are Torx nuts you need to take off. These are Torx bits:
Old May 2, 2008 | 05:10 PM
mjolnir's Avatar
T stands for torx and #50 is the size.
you should be able to buy them individually at any tool store, if you don't want to buy the whole set that is!
Old May 2, 2008 | 06:15 PM
jkinva's Avatar
Just be sure you hold onto the front doors when you take the straps/wiring harness off - don't just let it swing open. That mirror causes one heck of a ding! Many of us have one, some even have one on each side
That's not in the owner's manual.
Old May 2, 2008 | 06:23 PM
mjolnir's Avatar
and remember to take the straps wiring off first!!!!
Old May 2, 2008 | 08:12 PM
only_in_my_jeep's Avatar
I am one who has the door dings on each side. You also might need a t-40 it allows you to take the windshield bolts out as well as the hard top bolts for those of us with them. By the time you price both you may as well get a whole set. I did and got a stubby handle to go with them. I keep the set stored in the back inside the bag that the owners manual came in.
BTW you do not need to reinstall the nuts ever agian. Some people claim it makes them harder for people to steal I say if the jeep is locked (assuming you have the alarm) how do they get the door open to get the clearance neccessary to remove the door?
Old May 3, 2008 | 06:01 AM
Greystn JK's Avatar
It's a 2 step process. Slide the red tab over and then squeeze the button
I the first few times was very frustrated when the plug would not just slip apart. I first tried to pry it Just minor damage
