rock stuck in bead
Old Oct 1, 2008 | 04:01 AM
thegreathoe's Avatar
Default rock stuck in bead
i have a little *say 1/4 - 1/2"* really sharp rock stuck between my rim and my tire.... is there any way i can get it out myself easily without losing the bead? It doesnt seem to want to budge at the current psi i have the tire at, but i was thinking if i lower it some that might help... i just dont want to mess up the actual tire any.
Old Oct 1, 2008 | 05:40 AM
Fireguy0306's Avatar
If you lower the PSI, it should allow you to get the rock out, Just remember you might be better off losing the bead then tearing the sidewall.
Old Oct 1, 2008 | 08:59 AM
greenmachine07's Avatar
talk to a tire shop. they could help if there offorad friendly. if not than id go with what he said
Old Oct 1, 2008 | 12:43 PM
hntndawg's Avatar
I would take the wheel off, and let all the air out. Then you should easily be able to get it out with out damaging the tire.
Old Oct 2, 2008 | 04:54 AM
alrighty... thanks, i'll try to air it down completely 2nite and get it out
Old Oct 2, 2008 | 09:37 AM
RedRockJk4x4's Avatar
I had the same thing happen with a small piece of wood. I tried digging it out and pulling it out with pliers with no luck. I finally had to jack it up to take the weight off the wheel and aired it down almost completely and that gave me enough free play to get it out andI didnt loose the bead either. Good luck.
Old Oct 2, 2008 | 03:52 PM
TINMAN080's Avatar
air down, spray the rock with WD40, pop rock out with screwdriver. Air back up....
