Rubbing with 37's
First--its only rubbing on one side? Do you have an adjustable trackbar or bracket, or is your axle off center?
Second--don't freak out lol. They're rubbing on your frame, which is relatively smooth. And chances are you're not turning full lock at any crazy speed. Check to see if your axle is indeed centered first, then o would look at adding washers to your steering stops.
-Adam
-Adam
