Sealing the rubber seal of a light
Old May 25, 2011 | 07:39 PM
matt852's Avatar
Default Sealing the rubber seal of a light
Is there a special product I have to use If I want to watertight the seal on lights? Could I simply just use superglue? It's going to be for my rock lights.
Old May 25, 2011 | 07:49 PM
scouter4life's Avatar
Probably some hi temp silicone sealant would work. DAP makes some that you can probably pick up at a home store.
Old May 25, 2011 | 08:43 PM
matt852's Avatar
Thanks scouter, hey I remembered you also installed the Walmart rock lights, did they corrode after you put the sealant?
Old May 25, 2011 | 09:22 PM
Foolish me never put any on and the rubber seal cracked and contacts corroded badly. Next set, regardless of make, will get some sealant.
