Shifting
Old May 25, 2011 | 07:05 PM
jacksonbmx23's Avatar
Default Shifting
I drive a 6 speed and I usually shift early to keep the rpms down to save gas. Will driving in higher gears around town cause any damage?
Old May 25, 2011 | 07:07 PM
jcrcan25's Avatar
could...plus im not convinced that will save you gas
Old May 25, 2011 | 07:08 PM
jesse0376's Avatar
no you will be fine.
Old May 25, 2011 | 07:10 PM
jcrcan25's Avatar
it depends on what extreme he is doing it... i have seen people in such high gear they are jerking the crap out of it..... plus it wont save gas....
Old May 25, 2011 | 07:11 PM
matt852's Avatar
I heard the JK engine is most efficient at around 2100 rpm. So I usually cruise around 2100
Old May 25, 2011 | 07:13 PM
jcrcan25's Avatar
you could always plan the route so that you drive down hill the whole way......just go the opposite way your parents went to school....you know ....up hill all the way....while they walked bare foot in the snow!!!
Old May 25, 2011 | 07:16 PM
ronjenx's Avatar
Driving in the higher gears is OK as long as you are not causing the engine to lug.
That means not demanding power to accelerate, or climb a hill. You will have to shift up and down a lot.
Personally, I think it's better to stay in a gear that allows the engine to turn up a little.
Engine health will more than offset any small fuel savings of being in the higher gears all the time.
Old May 25, 2011 | 07:21 PM
jcrcan25's Avatar
6th isn't gonna hurt anything around town. It's pretty inefiicient and if you decide you want to move forward then you'll need to drop to 3rd to get some oomph. At 24mph in 6th I can get 24mpg.
I shouldnt even respond....because i have no clue what mpg i get....speedo is off because of 35's and most driving is offroad....my little hail damaged insurance totaled civic gets 35 mpg though!!!
Old May 25, 2011 | 07:28 PM
KDBinAZ's Avatar
I used to shift around 3k and now shift around 2k. Will also cruise around 40-50 in 6th but will need to downshift if I need to accelerate. For cruising I try to pick the highest gear and the jeep seems to do ok
Old May 25, 2011 | 07:53 PM
scouter4life's Avatar
I usually shift between 1500-1700 and get great mpg's. For 25mph I will have it in either 4th or 5th, never do 6th, 35mph I'm usually in 5th or 6th. It all depends on the road though.
