Shifting to 4 low - question?
Old Mar 8, 2012 | 10:39 PM
Jeeep!'s Avatar
Default Shifting to 4 low - question?
I have a 2010 JK unlimited rubicon and I am very happy with it but. I have a question. I watched the video from jeep that explains how to shift to 4 lo and that a little grinding is ok. They said you are supposed to do it while moving. When I try this I can not shift into lo rather transfer case shift will not move until I put the transmission into neutral. I have an automatic btw.. If I put it into neutral then I can go ahead and smoothly move to 4 lo. However I do not need to be moving to do this. Am I doing it wrong?
A related question though I have yet to have a need to engage the lockers - I have tried and all I see on the dash is blinking axle lock lights - shouldn't they just stay in. Yes I am in 4 lo when I try this.
Sorry for the silly questions folks.
Old Mar 9, 2012 | 02:34 AM
Rubicon10's Avatar
You have to be in nuetral and stopped not moving. They say to be moving but I have yet to see one that wont grind when trying this. Also after you engage your lockers you need to drive a little. Try driving forward for a little bit and then backing up. But if you drive forward for a little bit the light should turn solid. If after you drive it for a little bit and it still wont engage then it needs service and you have a problem. Has the gears been changed on this Jeep?
Old Mar 9, 2012 | 05:04 AM
Xman4602's Avatar
Originally Posted by BadTrainDriver
First, about the lockers, once you push the button in 4 wheel low, it may take a few seconds or a few slow revolutions for them to engage. Only if the pins inside the diffs are lined up(more likely to not be lined up than lined up) will it lock up immediately.
Second, kind of like the lockers, the gears must be lined up to shift into 4 wheel low.
Yes, you need to be in neutral with the automatic, and yes, you should be moving at less than 3 MPH.
To be the smoothest, you should barely be moving...like 1 MPH...
If you're stopped, and the gears are lined up, you good to go...but if they are not, it won't go.
Now moving slowly...like 1 MPH in neutral, it will go in ALL THE TIME.
That is why they say to be moving.
The same is true of my 6 sp. In neutral, slightest roll forward, smooth as silk.
Old Mar 9, 2012 | 05:50 AM
JamesWyatt's Avatar
Auto here... Yes, slightest roll goes without grinding. All can be done in the space of my super-short urban driveway. In D (transfer case in 4H) let off the brake a little and immediately put it back in N then shift to 4L while barely moving.
Old Mar 10, 2012 | 06:00 AM
jm102602's Avatar
I do it the same way without any grinding at all
Old Mar 10, 2012 | 06:16 AM
JamesWyatt's Avatar
Originally Posted by Bucko
While in drive??? You have success with this?
I've never tried that... successfully
Haha, no. I meant put the transmission in N right after you start moving forward, then move the transfer case lever from 4H to 4L in one smooth motion.
Old Mar 10, 2012 | 09:17 AM
Xman4602's Avatar
I believe if you read this post again he states he puts it back in N before the shift to 4lo.
Xman4602's Avatar
Oops didn't read all the way through before I commented. My bad.
Old Mar 10, 2012 | 09:23 AM
EzK's Avatar
EzK
I don't have an auto but why couldn't you shift into 4low while in drive if you are on the brake and going very slow?
Old Mar 10, 2012 | 10:36 AM
l00py1211's Avatar
Because the transmission when in gear has a load on it and when you disengage the t-case into nuetral, the transmission output shaft begins to freespin. At which point putting the tcase into 4-lo (or hi) will cause it to grind.
