Slowing down in neutral - going Down hill!
Okay guys any help on this would be appreciated. I was out this weekend and was going for a cruise in the jeep with the lid off and the sun shining having a good time. I came to a spot where normally I would put my previous cars in neutral and coast all the way down the hill. I usually gained speed at this point.
So here I am pumping it into neutral and it feels slow. I watched the speedometer and I was actually loosing speed, in neutral, coasting going down hill!
Has anybody else experienced this and does anybody know why? is there something I can do to make the jeep roll better?
You can spend like $1500 on a manual hub kit for the front axle, remove the front driveshaft. It's extremely un-aerodynamic, it has two live/solid axles and a transfer case that is all turning. Just about every JK rolls EXTREMELY bad as compared to almost any car. Very high rolling resistance.
Comes with the territory.
It just feels wrong that a 4000lb vehicle going down hill slows down lol...then again I guess you wouldn't have to worry about being out of control lol....just engage everything....
So if you're going highway speeds, then yes, it will slow down, because the aerodynamics are the limiting factor.
If you're going slow, then there is something else at hand.
At 70, it takes about a 5% grade to keep a constant speed, not going faster or slower.
it was about a kilometer long and a down slope of about 20 to 30 degrees. Like I said other cars have gained speed on this one. And yes I was going about 50 miles an hour when i put it in neutral.
I don't know about your hill but coasting down anything in neutral is dangerous. If you had the need for a driving maneuver that required powering away from someone/something you would be ...... out of luck. In most states here coasting downhill is not legal for that reason.
