Spare Tire Under the JK????
Was thinking of this the other day........
Seems like most every other vehicle nowadays has the spare on the underside of the vehicle. Certainly a convenient out of the way place. Not so much if you are off road and need to change it. I wonder why the JK doesn't go this route. Here's what I came up with 1. It's an iconic look to have the spare on the tail gate 2. Fitting it would be a pain as the rear end is so close to the rear of the vehicle 3. Full size spare wold be very difficult to fit underneath. Any other thoughts? Way back, I had a full size Chevy Blazer with a full size spare in the back cargo area. It took up a lot of space! |
There is no room. Where would you put an upgraded wheel/tire?
The spare is completely fine where it is. |
It would be a pain the ass to change offroad
Originally Posted by rebar81
(Post 3178051)
I like the old land-rovers with the spare on the hood, but don't think I could see much with mine there.
You wouldn't be able to fit anything past a 35 if that, and you're losing a ton of ground clearance.
Think of it as armor.
:D |
what if your "armor" got punctured on the trail and then you actually had to use it as a spare? guess the aftermarket could come up with a skid plate for your spare! I guess the question I have for the OP is what got you thinking about this? Is it in your way when you try to load stuff in the back?
Get a cargo rack and put it on top
