Still learning...
Old Feb 8, 2008 | 06:05 PM
bobzinger's Avatar
Default Still learning...
So, I'm relatively new to the Wrangler scene. I just have a couple questions that I've haven't found the answer to by doing a search...
- What are the Dana axles that I keep reading about?
- I have an 07 Unlimited X so, which one would I have?
- Is there someplace where I can punch in my VIN and find out everything I want to know about my Jeep (i.e., equipment, etc.) I bought my Jeep used.
I think that's it for now. Thanks for info. Sorry for the newb questions.
Old Feb 8, 2008 | 06:09 PM
jeepcanoe's Avatar
Don't tell your bride you have a jeep ....she'll always want to play with it.
Old Feb 8, 2008 | 06:13 PM
Robar's Avatar
- Dana is a company that makes axles for vehicles. The numbers like 44, 30, 35, are model #s that Dana uses.
- You most likely have a Dana 30 front axle and a Dana 44 rear axle.
- You can contact your dealer and ask for a build sheet. They can enter your VIN and print it out. It has all the specs and info for your vehicle.
Old Feb 8, 2008 | 06:15 PM
bobzinger's Avatar
Sweet... thanks.
Old Feb 8, 2008 | 06:16 PM
yellowjeeper85's Avatar
hello there, happy to help clear that up for you. there is somewhere you can punch in your vin... or at least use you vin to find all that out, however, i don't have the link... sorry, but as for the other stuff, i can help.
Dana axles are basically the name brand of the axle that chrysler uses, and some other car companies have used/do use, but chrysler/Jeep uses them. Ford trucks often have a ford 8.8 ford 9" or some other axle... the 9" being larger than 8.8
With dana Axles in their stock form, its almost always better to have the larger number, such as a Dana 44 over the Dana 35. Though i've heard some compelling arguements where the 30 is better than the 35... anyway, not to confuse you, but the rule of thumb is, with a dana axle the larger number the better. Being that you have an X model, your front axle is a Dana 30 and since you have an unlimited, your rear axle is a Dana 44. I beleive that holds true on all the JKs that only the Rubicons get a front 44 and all unlimiteds get the Rear 44 however i know it to be true for the 07, as mine is an 07 and when i baught mine it was in 06, so all my Homework for Jeep shopping was done on the 07 models.
Again, not to confuse you, your front is a Dana 30 and your Rear is a Dana 44
As for Gear ratio, being that its an X, you should have the 3:21 gear ratio if you have a manual transmission, unless you have the tow package, then you have the 4:10 gears... lastly, if you have an automatic and a tow package you still have the 4:10 gears, but if you have an automatic and no tow package, well then i'm not sure whether you have the 3:21 or the 4:10... i only buy stick shifts so i never did the Homework on the Automatic gear ratios
I know you didn't ask about gear ratios, but its a common question here on the site, and goes pretty hand in hand with the Axle size info. I hope that helps and keep searching the site for the vin number info, i know its on here somewhere. good luck
Old Feb 8, 2008 | 06:21 PM
bobzinger's Avatar
Excellent information! I was curious about the gear ratio. I do have an auto w/o the tow package. Since my Jeep's in the shop anyway so when I go to pick it up, I'll ask for a spec sheet.
Thanks very much for passing on the info.
Old Feb 8, 2008 | 07:21 PM
JK Dawg's Avatar
Not sure about '07, but for 2008 all ATs (except Rubicons) have 3.73 gears.
Old Feb 8, 2008 | 07:30 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
my 2007 X came with 4:10's with the tow package and auto.
Old Feb 8, 2008 | 07:48 PM
rdrubi's Avatar
I sent completed the form below from Jeep's Website and my build sheet was emailed to me. It took a couple of weeks... but, it came. Absent the underhood light and rear cargo ties; it was all there. Be sure and specifically request the "Build Sheet" under Comments Section.
http://www-5.jeep.com/wccsapp/univer...ull&category=U
I have cut and pasted mine so you have an idea of what to expect. As was previously mentioned - if you purchased from a Jeep dealership they can get you the same thing. If you purchased from a non-Jeep dealer/private party you may be forced to email and wait! (I have edited out my personal information)
Enjoy your Jeep!
Thank you for contacting the Customer Assistance Center for 2007 Jeep
Wrangler Unlimited Rubicon.
According to our records, your vehicle was equipped from the factory
with the following:
Prem Cloth Low-Back Bucket Seats
Dk Slate Gray/Med Slate Gray
Dual Top Group
Trailer Tow Group
Power Convenience Group
Monotone Paint
Smoker's Group
160 Amp Alternator
600 Amp Maintenance Free Battery
Electronic Stability Program
Traction Control
Electronic Roll Mitigation
Hydraulic Assist Brake Booster
4-Wheel Disc Brakes
Low Back Bucket Seats
Reclining Front Seats
Driver Height Adjuster Seat
Rear 60/40 Folding Seat
Next Generation Front Air Bags**
Head Restraints Outboard Seating
Supplemental Frt Seat Side Air Bags
Front Seat Area Carpet
Rear Seat/Wheelhouse/Cargo Carpet
Cargo Tie Down Loops
Front & Rear Floor Mats
Sport Bar w/Full Padding
Full Length Floor Console
Removable Ash Tray
Rear Compartment Storage Tray
All 4-Speed Automatic Transmissions
4-Spd. Automatic VLP 42RLE Trans
4:1 Rock-Trac HD Part Time 4WD Sys
Next Gen. Dana 44 HD Front Axle
4.10 Axle Ratio
Next Gen. Dana 44 HD Rear Axle
Tru-Lok Front & Rear Axles
3.8L V6 SMPI Engine
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Windows
Full Metal Doors w/Roll-up Windows
Rear Window Defroster
Rear View Day/Night Mirror
Driver Side Sun Visor
Passenger Side Sun Visor
Swing-Away Mirrors
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Hood Insulation
Instrument Cluster w/Tach
100 MPH Primary Speedometer
Temperature & Compass Gauge
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Cigar Lighter
Single Low Note Horn
12V Auxiliary Power Outlet
Locking Glove Box
Power Locks
Pwr Windows, Front 1-Touch Down
STRIPE/BADGE/MOLDING/COLOR
Courtesy Lamps
Underhood Lamp
Rear Dome w/On/Off Switch Lamp
Halogen Headlamps
Fog Lamps
CHMSL Lamp
Security Alarm
Painted Front Bumper
Black Rear Bumper
Black Diamond Plate Sill Guards
Black Front Frame Overlay
Body Color Grille
Trail Rated Badge
Jeep Badge
Federal Emissions
23 Gallon Fuel Tank
Speed Control
Flame Red Clear Coat
Premium Speakers w/Subwoofer
Fixed Long Mast Antenna
6 Disc DVD MP3 Radio
Sirius Satellite Radio
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Performance Suspension
Front and Rear Stabilizer Bars
Front Disconnecting Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Outside Tire Carrier
LT255/75R17 BSW Off Road Tires
BF Goodrich Brand Tires
Black Soft Top
Black Hard Top
17X8.0 Alum Machined Cast Wheels
Matching Spare Wheel
All Aluminum Wheels
Occupant Classification System
Delete Rear Tow Hook
Fuel Tank Skid Plate Shield
Transfer Case Skid Plate Shield
2 Front & 1 Rear Tow Hooks
Transmission Skid Plate
Class II Receiver Hitch
UP Trailer Tow w/4-Pin Connector Wiring
YES Essentials(R) Seat Fabric
Tethered Fuel Filler Cap
Locking Fuel Filler Cap
Protective Coating and Remover
Instrument Panel Parts Module
Front End Parts Module
Complete Chassis Parts Module
Tire & Wheel Parts Module
For More Info, Call 888-539-7474
Complete Body in White Parts Module
Complete Painted Body Module
1-Year Service Provided by SIRIUS
Build To U S Market Specifications
Manuf Statement of Origin
5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
GVW/Payload Rating
40930-101 Mga 0AJ
Dealer Retail
Zone 35-Washington
Customer Preferred Package 2TR
Customer Preferred Package 24R
JK-Vehicle Family
Four Wheel Drive (4WD)/(4X4)
Left Hand Drive (LHD)
Four Door
Status D1 to D Less 100%
Vehicle Order Tracking
Long Wheel Base (LWB)
Paint Order Code
If we can be of any further assistance please let us know.
Thanks again for your email.
Sincerely,
Stanley Keith
Senior Staff Representative
Chrysler Customer Assistance Center
For any future communications related to this email, please refer to the
following information:
REFERENCE NUMBER: 16937824
EMAIL CASE NUMBER: 1872542
REPLY LINK: http://www.chrysler.com/wccs/brand_forms/us/reply.jsp?trk_ID=KMM5280351I25261L0KM&
Original Message Follows:
US Customer Service - Jeep Brand Site
Brief Description:
Requesting of Build Sheet/Options Report
Comments:
I would like a detailed copy emailed to me of my build sheet/option
report.
Thank you.
VIN:
7L112706
Mileage:
30100
Servicing Dealer:
Dulles Jeep
Old Feb 9, 2008 | 03:45 AM
bobzinger's Avatar
Wow... looks like they send you just about everything you need to know. I'm surprised they didn't include the quarater and dime that fell between the seat.
Thanks for the info... I'll check it out.
