stock rear bumper
Old Aug 2, 2012 | 05:48 AM
mojoe's Avatar
Default stock rear bumper
what is the maximum tire size the stock rear bumper can hold?
will it hold 33s? thanks!
Old Aug 2, 2012 | 05:50 AM
Noxian's Avatar
I think you meant he stock tire carrier, and yes it should hold a 33 assuming you make sure it rests on the rubber stops behind the wheel making sure it doesn't bounce around.
Old Aug 2, 2012 | 05:57 AM
mojoe's Avatar
yes sorry.. the stock tire carrier. i assume if i get bigger tires, it will hit the stock rear bumper.
Old Aug 2, 2012 | 08:15 AM
mojoe's Avatar
anyone else has 33s and has no problems installing the spare on the stock carrier and rear bumper? thanks.
Old Aug 2, 2012 | 08:39 AM
951JEEP's Avatar
I think its worth mentioning it also depends on the tire; a 33" GY Duratrac weighs about 50lbs, whereas a 33" Toyo MT is closer to 70lbs. Not to forget about the weight of the rim as well. (Im fairly new yet, and Im not aware of what the stock configuration weighs)
Old Aug 2, 2012 | 08:55 AM
moz832006's Avatar
Yup, it holds my 35in. My tire is a heavy toyo open country M/T which is about 96 lbs and my rim about 30lbs. No problem at all, even in bumby back roads or trails at high speeds.
Old Aug 2, 2012 | 09:04 AM
mojoe's Avatar
cool thank you!
Old Aug 2, 2012 | 09:10 AM
holmes4x4's Avatar
Where mine wouldnt fit my 35s it actually looked as though it was bowing my tailgate when I went off road. Day 3 and ended up just buy a whole new tire carrier and bumper. 33s will fit fine though I also ran a GY silent armor in a 31(actual mesure just about 32) before the 35s and they fit perfect.
Old Aug 2, 2012 | 09:19 AM
619 JK's Avatar
I'm running a 33" Duratrac without issue, it fits in perfect.
Old Aug 2, 2012 | 09:51 AM
mojoe's Avatar
awesome news! I'm very low on budget and can't afford new tire carrier and bumpers right now.
For the 33s, what lift is recommended. I probably dont want to go too high as that might be too weird with small 33s right?
I'm open to spacer lift to save some money too. Thanks.
