Superchips Wishlist
Superchips Wishlist
Just curious as to what additional features people would like to see from their Flashpaqs. Also if there is some portion of the feature set that needs to be honed or improved.
Try to limit it to 5 items and rank them.
Here's mine (6 speed)
1. Full time idle adjustment (w/o being attached)
2. Disable ESP
3. Adjustable rev limiter
4. WOT Fuel settings (closed loop)
5. PCM reset (same as pulling fuse)
I'm sure there's more and especially for the auto transmission guys.
2. Disable ESP
2. Disable ESP
2. Disable ESP
6. Transmission temp display
7. MPH display (more accurate than the spedo)
8. Engine load and more canbus stats.
9. TPMS troubleshooting (eg. why there's a fault - what sensor is low/missing).
10. Ability to view/modify TPMS sensor ID's (hate going to the dealer for this)
2. Disable ESP
2. Disable ESP
1. How would you plan on adjusting the idle adjustment without it hooked up? Or do you mean change the idle rpm permanently, then remove the tuner?
3. Why?
Forgot to add mine,
11. 2wd locker use (with tuner hooked up is okay with me)
12. Fan adjust ability with a/c control? I'm not sure if that is offered yet, I know you can alter the temperature on which it is triggered. I've found the fan to come on and high temps/pressures at idle with the a/c on, i would prefer the fan to be on high speed around town with the a/c on. Really would help the a/c efficiency with the JK.
13. Some OBD II live data information would be nice.
3. Tires unhooking in the snow or mud can cause a spike in your rpms in a hurry. Not really that big of a deal, but the rev limiter doesn't kick in until around 5800 rpm. That's a little tall for me and I'd rather be hitting the rev limit earlier. Some of course may want to go a different direction.
1. Yes a full time idle adjustment, so the rpms are bumped a bit. I've played around with it before and a 2-300 rpm boost means a lot less feathering of the clutch. It also opens the door to a 20% under-drive damper so it wouldn't discharge the battery at low rpms with the AC on and doesn't need to spin the accessories as hard at cruise speeds, eating power.
On the rev limiter i thought you wanted to raise it
Also, there is a fair amount of OBDII live data already. Not Aeroforce Interceptor depth, but a decent variety. It would also be nice if they had a windshield mount bracket and holder available. That would also suggest a right angle OBDII connector to keep the cord out of the way.
