Thoughts (Starting Issues)
The throttle body doesn't see fuel so won't see seafoam. Also, be careful using seafoam with fuel that contains ethanol as seafoam is a 'hydrocarbon blend' with isopropanol (alcohol)
I try to stay away from ethanol, sorry when you said throttle body my mind was on injectors. My wife and I are out right now store hopping in the jeep no problems at all. Starts fine every time. It's worse over night.
Fuel pressure is supposed to be 58 ±2 psi.
Not sure why you would pull a vacuum line, or why the fuel pressure would change after doing so.
The fuel pump gets power while the engine is cranking, and all the time the engine is running.
