Tire/flare Laws by State
#21
28-958.01. Rear fender splash guards
A. A person shall not operate a truck, trailer, semitrailer or bus on a highway unless the vehicle is equipped with rear fender splash guards that comply with the specifications provided in this section.
B. The splash guards:
1. Shall be attached in a manner that prevents the splashing of mud or water on the windshield of other motor vehicles.
2. Shall extend to a length of not more than eight inches from the ground.
3. Shall be wide enough to cover the full tread or treads of the tires being protected.
4. Shall be installed close enough to the tread surface of the tire or wheel to control the side throw of the bulk of the thrown road surface material.
5. May be constructed of a flexible rubberized material.
6. Shall be attached in a manner that, regardless of movement either in the splash guards or the vehicle, the splash guards retain their general parallel relationship to the tread surface of the tire or wheel under all ordinary operating conditions.
C. This section does not apply to:
1. A vehicle commonly known as a pickup truck with a manufacturer's gross vehicle weight rating of ten thousand pounds or less, except that this section applies if the pickup truck has been modified from the original bumper height design to raise the center of gravity of the pickup truck.
2. A truck tractor or converter dolly when used in combination with another vehicle.
3. A single, tandem or triple axle trailer with fenders that are wide enough to cover the full tread or treads of the tires being protected and that extend to a length of not more than fourteen inches from the ground.
#22
in maine i believe its illegal to have any rubber outside of the flares at all..a buddy of mine has a TJ on 35"s that he bought and he said he had to get new flares because of the rubber sticking out further. strange state sometimes
#23
Au contraire, my friend. Doesn't apply unless your Jeep is lifted (OK. Could argue a Jeep is not a "pickup truck"). From Arizona Revised Statutes:
#24
I called the PA. State Police about driving doorless.You Must have a seat belt for every passenger and You Must have your outside mirrors located on the body of the Jeep.I have passed many police and I even went to the state police barracks with the roof and doors off.There were cops standing outside when I pulled in and they never said a word.One asked if I liked the 4-door better than the 2-door.
