Tire pressure???
My question to anyone is what would be the proper tire pressure for (ON) road use. I am running 37 X 12.50 TSL Irok. The max PSI. says 65 PSI. I set them at 60 PSI. Any opinion on that reference proper tire wear. I know a little less would maybe make a better ride but the price of tires I would sacrifice ride for wear you know what I meen? Thanks alot for any info...
I guess I should say when I'm driving to the mall
DUDE! OMG!
back them babies down! it has to like trying to drive a basketball!!!!
yeah man, put them down to 30psi i wouldn t run more than 35 to 40 in them. start at 30 then adjust from there. i personally run 28 psi in my 33's and it is good.
back them babies down! it has to like trying to drive a basketball!!!!yeah man, put them down to 30psi i wouldn t run more than 35 to 40 in them. start at 30 then adjust from there. i personally run 28 psi in my 33's and it is good.
did you try matching the spare? I'm about to try this out and see if the TPMS will go off if all 5 are the same
