tired of it..
we've been getting a ton of rain here these past few weeks and my jeep has been leaking each day it rains. it leaks the in cornors of the driver and pass. front doors right near the windscreen. any ideas on what to do? anyone else have this problem?
It's the stupid foam....it compresses overtime and as a result the door seal is not as tight and the foam becomes so saturated with water from longer rains with this combination you get your leak...Only thing that has worked for me.......Just replace the older foam with new/thicker foam
finally...those little buggers fell on the ground the first time i put my top down, and it leaked ever since. I never knew where they went, and neither did the dealer. Seems kind of lame to depend on something like that for sealing a brand new vehicle, but then again Chrysler is going under so what does it matter.
Closed cell foam .... aka seal foam. add it to the area's that are leaking to build up the seal. same shit they use for like toppers for trucks.
http://www.apiclamps.com/tape.html
