Torque Wrench Recommendation
Old Mar 26, 2009 | 05:13 PM
ronjenx's Avatar
Originally Posted by berg
Depending on the wheel, you may need an extension for the socket.
I can't remember do you add or subtract torque when using an extension?
If it's a regular straight extension, like you would get in a socket set, no change in torque required.
If it's an extension to make the length of the torque wrench longer, set it to a 90 degree angle. No change in torque required. Otherwise, there is a math formula to do.
It is generally accepted practice that crow's feet need no compensation.
Old Mar 26, 2009 | 05:21 PM
berg's Avatar
Thanks I appreciate that
Old Mar 26, 2009 | 05:42 PM
SI-Jeeper08's Avatar
Can't beat them. Rugged, dependable and reasonably priced.
I have a Craftsman.
But do you really need to set your lug nuts to a specific torque?
If a specific torque was required to safely attach your wheels, wouldn't there be some sort of torque wrench supplied with your jack and spare? And wouldn't there be some safety warning lable saying "wheel lug nuts must be torqued to XXX ft/lbs before driving"?
Just get them good and tight with the factory lug wrench.
Thats all I have ever done and have never had a wheel fall off yet.
If you do use a torque wrench remember to use it only to set the torque. Not to loosen the lug nuts.
What ever you do. Make sure you can loosen the lug nuts with the factory lug wrench or whatever wrench you will be carrying with you. When (not if) you have a flat is not the time to realize that you can't change your tire because you can't loosen the nuts. (Experience talking here)
I've never had a clue what the torque specs were on any of my vehicles. I remember my dad telling me "tighten 'em down as tight as they'll go, then give 'em another half turn." Never had a wheel fall off yet.
Old Mar 26, 2009 | 05:52 PM
Geezle's Avatar
Ditto, my dad taught me pretty much the same thing.
I can see the obvious problem with under tightening, but is there any negative to over tightening, aside from having a hard time getting them off later?
Old Mar 26, 2009 | 06:06 PM
ronjenx's Avatar
Damaged wheel
Warped rotor
stripped nut
stripped or broken stud
But what do I know. I've been applying proper torque for 37 years. The one time I didn't ('62 VW bus, 32 years ago), the right rear wheel disappeared up into the body.
Old Mar 26, 2009 | 06:15 PM
Damaged wheel
Warped rotor
stripped nut
I guess I'm fortunate not to be strong enough to get them that tight by hand then. They seem to come off easier after I've rotated them myself than after I've bought new tires installed at the tire shop.
Old Mar 26, 2009 | 06:20 PM
ronjenx's Avatar
I will admit, they most likely will not get overtorqued to the point of damage, by hand. The people who use the impact wrenches are the guilty ones.
Old Mar 26, 2009 | 07:04 PM
bly109's Avatar
Ive broken a few grade 8 1/2" & 9/16" bolts by hand before... with just a 18" bar.. Ive snapped a few lugs.. Ive also split SK impact sockets by hand...plus I eat green locktite for breakfast.. so yes, you can damage bolts by over tightening.... Thats why I rather know if Im over tightening or under tightening. It only adds a few minutes, so for me its well worth it. And my dad never told me to tighten them as tight as you can.. he snapped way too many bolts in his day too, so he knows better.
And to the OP, you really cant beat a beam style for dependabilty and price.
Old Mar 26, 2009 | 07:40 PM
kafka1983's Avatar
Default Thanks
Thanks guys. Good stuff. The Forum is useful as ever. Plus I a got a record number of responses in just a few hours (for my threads anyway).
