Towing
if you're gonna re-gear, might as well go all the way. Especially if you ever plan to run bigger tires, etc.
Let's clear this up a little. Your jeep is rated based on brakes, cooling, transmission, length, etc. That's how they derive the tow rating The smitty bumper can "tow" 6000lbs because that's the safe limit they've determined for the steel and welds. Yet another example of a company creating a little bit of skewed advertising. It's like the mighty mend it glue- "watch it pull these dump trucks" but they are still bolting and welding those things together instead of using that glue. Do as you please and believe what you'd like, folks here will ask for information and then go do the opposite.
not all of what you said is true. The Jeep Wrangler tow rating is NOT based on its physical tow capability in the US. I researched this a lot prior to ordering my JKU. In the US, the JKU is a convertible since the top and doors do not protect the occupants. This is a factor in the US keeping the rating artificially low. Some other countries rate the exact same JKU (not diesel) for up to 4400 pounds. Consider this: there are jeep liberties that are rated in the US to tow 5000 pounds. There is not one hint of evidence that says any Liberty should be able to tow more than any JKU. The Liberty weighs less, has a shorter and narrower wheelbase and has considerably less power.
Never said that your bumper wasn't. I'm pointing out to the poster that most replacement bumpers use a port to allow the OEM receiver hitch to pass through. FWIW, the jeep is only rated to 3500lbs (Class II). The XRC is class III (6,000lbs) so that's good, but doesn't mean you can tow 6,000lbs with it. I know folks do it, but it's not a recommended practice.
I don't deny that what you say is true. However, I put a post on here a couple years ago reaching out to the community to see if anyone has real world specific examples of someone being sued or charged for towing a heavier load than the vehicle was rated for. I think the responses did not include any proven examples. But, people sue for anything so you are certainly not wrong that this could happen. I was willing to take the chance, knowing I did everything possible to ensure a safe tow, even though it was over the rated limit.
I can agree with most of you on this topic, I've got plenty of experience pulling just never pulled anything with the Jeep cause it was bought for my wife originally but now we're going to get her another vehicle and I'm looking to get the Jeep and will probably be doing a lot of modifications to it, just looking for advice from outside experience
Yeah by weighing out both options just a receiver hitch and an after market bumper, I definitely believe that a bumper would be better mainly because it would provide more stability than the receiver just bolting to the cross member. I never would have much faith in the cross member
