Tpms sensors.
Aev procal huh? What else does this do? Guess I was hoping for a quick turn the key on and off 3x while holding the window up button and getting someone to throw a chicken bone at the right headlight sorta fix. Ha
ProCal Module Functions:
Tire Size
Gear Ratio
One Touch Lane Change
Daytime Running Lamps
Low Tire Pressure Indicator
Smart Bar Indicator Disable (after Smart Bar removal)
Clear Diagnostic Trouble Codes
While plugged into the OBD port, the ProCal Module can also:
Set a Temporary Extended Idle
Provide a Dead Center Steering Wheel Indication
Clear Diagnostic Trouble Codes / Turn off the Check Engine Lamp
For AEV HEMI Builders Kit customers, the ProCal Module will:
Program the Vehicles VIN into the new PCM Controller
Program the Pedal Calibration and Tolerance
Tire Size
Gear Ratio
