tranny and transfer case
Old May 13, 2009 | 07:54 AM
foleyage's Avatar
Default tranny and transfer case
thinking about doing a fluid swap for both . what do you guys recommend for doing the changes .. what oils ..Synthetic oil or regular oil
do i need to do anything special to do this . moddifier
thanks in advance
Old May 13, 2009 | 08:15 AM
atuldo's Avatar
http://project-jk.com/jeep-jk-write-...r-case-service and the tranny (should be good for some time..)is as easy-all synthetic
Old Jul 1, 2009 | 07:48 PM
homer's Avatar
go with syntethics. They make things shift smoother and are a bit more quiet.
The thing that pissed me off is when I went to change the transfer case fluid, it seemed low to my finger test, so I drained and measured it. the unit was at least a pint low from the factory. Glad I got to it early in its life.
I used sychromax in the 6 speed and Havoline atf+4 synthetic for the transfer case.
Also remember to anti siezed the plugs on both cases. They will corrode in place otherwise.
homer
