What's up with the grill screen inserts?
I've got to ask after seeing several "mods" with grill screen inserts. WHY? That cuts the air coming through the grill by at least 50%. Just begging to get mudded up and overheat. I know everyone will say "I haven't had a problem yet..." It still cuts the air flow to the radiator which means the engine will run hotter all the time even if it doesn't overheat.
Can't see any benefit to asking for heat problems.
i put mine to avoid rocks hitting my radiator , then i was told it very rarely happens but i had already had them when told this, if i ever have problems with overheating then i will remove them .
If I was going to be driving through something, like it looks like you must have driven through, very often, I think I would design a screen to put on the front of your grill. Something you can put on or take off very easley, it would really cut down on the clean up time.
