Whats your secret mod?
#21
I removed that chip that "the man" puts on to keep big oil in business. I am now getting over 900 mpg, also without the chip I can accellerate 0-60 in about 4 seconds. I would tell you were the chip was, but then it wouldn't be a secret.
#22
#23
#24
#27
Originally Posted by kooty
I have a secret switch , if you push it down the window goes down , if you push it up , nothing hapens
#28
#30
I installed a 7 inch handheld tv in the small space behind the rectangular panel that is the lower panel under the steering wheel. I assume the panel is there to access the stock amp on my 2010 JK sahara. To access the tv I pull off the panel and pull the tv out. The tv is mounted on two flat pieces of metal that are attached to each other but slide out. The tv is mounted on that tray and is facing up. When pulled out the tv is angled to face the driver.
I made a diagram of the simple tv tray the tv slides on.
I still need to get an extra lower panel so I can cut off the tabs, install a rudimentary hinge and some velcro so that the panel can easily open and fold down.
I also installed a 3 pole single throw toggle switch in my dash that turns off my brake lights when I need it. Note: the three brake lights are on their own circuits so they need separate switches or one switch that is a 3 pole single throw.
