wheel spacers
Wheel spacers pros and cons need input
Wheel spacers are bad, avoid them. wheel adapters are fine and is what most people use. Follow the instructions with loc-tite and proper torque and you should not see any issues. If you are looking for a solution for oversized tires most bigger rubber manufactureres recommend a wheel wider then stock and generally in the 8"-10" range.
Originally Posted by TheDirtman
(Post 4309217)
Wheel spacers are bad, avoid them. ...
look for "hub centric". I have had mine on for 3 years, always check 5# under the torque setting. I run my lug nuts at 105#, and check the spacer lugs at 100ft#. never had one back off. I check the spacers every 10,000 miles, when I do the 5 tire rotation.
