Wheel spacers and corrosion
Next Monday I will receive my spidertrax wheel spacers from Northridge Canada :yup:
I read somewhere that corrosion (of the aluminium) can be an issue with the wheel spacers after many years What can I do to prevent corrosion of the wheel spacers? Grease? oil treatment? any other suggestion :dontknow2: |
Originally Posted by JKU Rubicon
(Post 2186481)
Spidertrax are anodized, which will cut down mightily on corrosion, spray bomb the mating surfaces of the spacer and the hub with rustoleum. Let both dry then reassemble.:beer:
Originally Posted by TINMAN080
(Post 2188223)
Originally Posted by ECHO
(Post 2186717)
Get a bottle or tube of anti-sieze - apply it to the hub where the spacer meets:wink:
Originally Posted by skibum
(Post 2191411)
X2. Annodizing and paint don't work all that well (at least here in the snow and salt capitol of the entire civilized world). Three months after we put Spidertrax spacers on my daughter's TJ I went to rotate the tires and couldn't get two of them off without a lot of sweat and aggravation. Since then, I've coated the back of the spacers in anti-seize and I've never had another problem. :yup:
I don't see why it should be a big issue, your wheels are aluminum no different from the spacers. there shouldn't be any more corrosion with the spacers after a few years than just the wheels.:thinking:
(Post 2186717)
Just a small bit of helper info here from an OH SH$T back in the day, if you do put anti seize on the hub use a VERY small amount. A seemingly small amount added to it will seep and capillary action to lots of different places like your lug nuts. Trust me from expirance when your driving and see a lug nut fly in front of you and you think to your self man somebody's about to have a bad day! then some Karma comes in and some weird vibrations. and whammo you lost 3 lug nuts and the studs are magically covered with anti seize. luckily i stopped before the tire came of but i did spend 4 hours that night on the side of the road installing new studs. |
Originally Posted by Mariner
(Post 2192657)
Originally Posted by Tweakecho
(Post 2192743)
