Winch bumpers
Old Apr 5, 2021 | 09:43 AM
Dat's Avatar
Dat
Default Winch bumpers
Ok, I’m finally looking into a bumper to mount my winch, an old Ramsey 9000 rep, I’m wanting a low mount inside/ recessed mount. I know you get what you pay for and I’m not looking a a cheap way out but I don’t want to spend a grand on one either.
I guess more that asking what brands people like, I’m looking more for brands to stay away from, or what is liked about different brands
Old Apr 5, 2021 | 09:51 AM
karls10jk's Avatar
Rugged ridge had the old XHD style that was pretty solidly mounted. You could remove the winch without taking the bumper off. I moved to a knock off stinger for a while and just using those 8 bolts across the front, you could get the frame horns to move. After that, I went to the Genright (clearance, before they started branding everything) and it's been solid for how it mounts and what it does. I know you mention that you get off the beaten trails, you might want one mounted a little more solidly than just the 8 across the front.
resharp001's Avatar
Loved
Community Favorite
Gosh, I haven't looked at front bumpers in a long time. I was gonna say a Smittybilt XRC isn't a terrible option, but dang, for another $120 you up to a PSC Bruiser bumper with recessed winch, and you get a lot better bumper. I've always felt a front bumper is one of those items you can get by with just about anything. The issue with cheap off-name bumpers is primarily going to be fit and finish. Guessing you don't want to block that radiator any more than necessary and that is why you're against a simple winch plate on your factory bumper.
Old Apr 5, 2021 | 10:30 AM
Dat's Avatar
Dat
A lot of not just going with a winch plate is looks, I just don’t like the way they look, and I like a lower mounted winch, that way it pulls up instead of pulling the bumper down and forward, higher mounted winches work well when pulling someone else out, but being in a 2 dr jeep I don’t have enough weight to do much pulling anyone else out,
im probably putting too much thought in on it
Old Apr 6, 2021 | 11:09 AM
Mr.T's Avatar
Community Favorite
I like low mounting as well, less tendency to twist under load and more air through the radiator. Been using a RR XHD for many years and it fits the bill.
Old Apr 6, 2021 | 02:58 PM
nthinuf's Avatar
I'm running the RR XHD also. They've apparently gone through a few revisions since I put mine on in 2008, but it's been a solid bumper for me.
Old Apr 13, 2021 | 06:27 AM
Dat's Avatar
Dat
RR xhd is ordered, I like that the fog lights are close to the original spot, not a heavy bumper, the winch weight and bumper shouldn’t make the front end drop as much as some of the others
Old Apr 13, 2021 | 06:30 AM
karls10jk's Avatar
I think you'll be satisfied with it, it's a stout bumper for sure and served me well when I had it.
Old Apr 13, 2021 | 08:49 AM
Dat's Avatar
Dat
I figure I may add a bracket from the bottom of the winch plate back to the frame, will do some figuring when I bolt it up on what it may need
Old Apr 13, 2021 | 10:33 AM
karls10jk's Avatar
So the Genright magic happens where they bolt the bottom of the bumper to the crash bar and in to the top of the frame. They also slide a tray in for the winch that locks/ bolts to the inside of the frame rail. You may be able to use some similar fasteners and bolt to the crash bar and the frame- I don't recall how close that bumper sat to the crash bar. I didn't have much movement in mine though, it was the stinger bumper where it would flex the frame horns on those 8 bolts alone- just by leaning on it.
