winch issues!
Old Jan 25, 2012 | 11:44 AM
CosmoBlew's Avatar
Default winch issues!
Ok, here's the deal. I just installed my Smittybilt X20 winch about a week ago and I've only pulled it out and rolled it back in a couple times just for testing. I haven't truly tested it out yet. However, after a week I go outside to take my Jk out for a stroll and it won't start?? It won't turn over or anything. Fully dead. Now I've read up on it a bit and I know about buy a bigger battery,a better alternator etc. I just need some direct feedback!
Old Jan 25, 2012 | 01:16 PM
CosmoBlew's Avatar
You think it may have something to do with my ground wire? Nothing will come on. Dead as can be..
Old Jan 25, 2012 | 04:25 PM
CosmoBlew's Avatar
Bump!...
Thanks
Old Jan 25, 2012 | 04:45 PM
ThreadHijacker's Avatar
Before assuming you have a dead battery disconnect the negative wire and put a volt meter on it and check if you have about 12 volts. Make sure your meter is set to DC at some voltage higher than 12 so you don't fry the meter. If it's dead then you know your problem and you need to charge it, jump it or get a new battery. In case you don't know, don't try to check AMPS, you could fry your jeep electronics or get hurt. Voltage is safe to check though. If the battery doesn't hold a charge after you charge it up then you either have a voltage vampire in your jeep while it's not on or your battery is toast.
Old Jan 26, 2012 | 07:49 AM
CosmoBlew's Avatar
Originally Posted by jk.bushwacker
no lights nothing? yes chk the ground wires. hell i'd pull the off the winch cables and anything else u added new recently. u prob have something draining the battery, see if u can jump it and get it started. if it come back to life then try adding things back again. if u cant jump it: does it turn over at all? if not start chking fusses, pull that battery and take it to autozone or like store they will test it for free. also make sure ur battery terminals are clean.
Yea I think that's what I'll do. Just disconnect all of the wires I hooked up from the winch. I know it's gotta be that.
