Write up on Differential oil change
Whoever wrote that.... THANK YOU!!!!!!!
3/8 torque wrench w/ socket set 25$ Oil Catch pan 5$ 75W90 Gear oil 30$ . . Knowing I didn't get ripped off by the dealership...... Priceless!!!! Mr.Bunny |
x2...Did my first diff change with the help of the forum write-up. Good opportunity to learn something new and save a few bucks :clap:
Yup, did mine recently too...
Had a leaky RTV seal, so I picked up some lube locker gaskets and solved the problem without having to go to the dealer. |
Saved me a bundle...dealership wanted $150/differential:crazyeyes::naw:
Originally Posted by TripleJeep_99
(Post 1400805)
Originally Posted by westchester
(Post 1401084)
Eastcoast dealer wanted $220, it was easy to reply I'll do it myself. Can someone paste the write-up link, I need which diff oil spec to buy. Cheers
https://www.jk-forum.com/forums/show...rential+change I used 75W90 Royal Purple and is what Wayoflife used. Some people went a thicker oil in the rear if they were pulling a trailer. |
Im getting ready to do this as well, how do we know if we need to the additive for the rear diff?
Is there something I should look for on my window sticker? |
Originally Posted by Hellbound13
(Post 1401363)
Originally Posted by Northernmedic
(Post 1401642)
If you have a limited slip rear diff, then you need an additive IF using traditional oil. Full-synthetic oil does not require an additive. Someone correct me if I'm wrong
(Post 1401642)
