Colorado Trail Advice (Mosquito Pass)
Old Aug 14, 2015 | 08:58 AM
jksooner's Avatar
Originally Posted by pvanweelden
Definitely would want to be in 4 low. I just did that trail a month ago in a stock grand cherokee, so your rig was definitely capable.
If ever you are uncomfortable, a shelf road is not the place to be.
Fwiw, the trail had more rocks all throughout it than I expected.
What about sway bars? Is that east side a disconnect type trail?
Old Aug 14, 2015 | 09:52 AM
pvanweelden's Avatar
Yes. If you want an easier trail to tackle first, maybe try Weston Pass, as it is usually wide enough for vehicles to pass each other. It starts near leadville. As mentioned previously, pick up the Charles Wells trail books and use traildamage.com as references.
Old Aug 14, 2015 | 04:56 PM
GSDrubi's Avatar
If you want a trail a little closer to Denver you could try Loch Lemond. Close to Boulder you can do Switzerland Trail. Chinn's Lake is suitable for any 4wd vehicle. I was up there two weeks ago and didn't even shift into 4wd, and I'm all stock.
As far as when to disconnect sway bars, if I put it in 4 low, I disconnect. Every trail is different so you just have to make some judgement calls. Everyone has their own variables that they follow to decide if and when they disconnect.
Old Aug 17, 2015 | 06:46 AM
jksooner's Avatar
Thanks for the recommendations! I will definitely check these out. We have 4 kids, two of which are my stepsons, so maybe on a weekend they are with their dad we can try Loch Lemond or Switzerland
Old Aug 17, 2015 | 09:55 AM
juggernutz's Avatar
Originally Posted by thegoat
Best advice if going it alone is to get the Wells book "Guide to Colorado Backroads & 4-Wheel-Drive Trails", there are other books depending on where you are wheeling. I started coming back home to Colorado every year with my Jeep from Texas and found the Wells books to be very accurate in trail descriptions as well as difficulty ratings. I have wheeled mostly by myself, so the books are helpful to avoid getting into a bad spot. Start with Green trails and when you are bored or want something more difficult tackle a Blue trail. You will build confidence over time.
Some of the rocky trails look intimidating but its no more difficult than rolling over a curb, well a couple hundred in row . Put it in 4Lo and take your time, bumping isn't the end of the world. Use 4Lo on the downhill parts and if you have an auto go to low gears and control your speed with the throttle.
+1 on the guide book (Guide to Colorado Backroads & 4-Wheel-Drive Trails). It's the perfect trail companion. Hey, if you ever want to hookup for some wheeling I'm in Castle Rock too. Let me know.
Old Aug 17, 2015 | 11:01 AM
jksooner's Avatar
Would love to!
Old Aug 17, 2015 | 04:15 PM
MTNBKR's Avatar
Originally Posted by jksooner
Would love to!
Jksooner. U from Ok??
Old Aug 18, 2015 | 06:43 AM
jksooner's Avatar
Originally yes... moved to Colorado 6 years ago
Old Aug 20, 2015 | 07:45 AM
MTNBKR's Avatar
Nice. From OK originally also. Have vaca planned to wheel in CO in summer of 17
