Shamrocked 2010 - 4th Annual Project-JK Newbie Run & Party in the Desert!!
Old Mar 16, 2010 | 04:15 PM
  #31
shredX's Avatar
If knock off the evap canister, can you keep wheeling and get home? Or, does it go into limp mode and you're in trouble?
Thanks and great pics.
Old Mar 16, 2010 | 04:19 PM
  #32
wayoflife's Avatar
JK-Forum Founder
technically, you don't even need the EVAP canister - it simply exists to help your gas tank breathe and keep gas fumes from get out into the atomphere at the same time. in fact, your jeep won't even know that it's gone for a while and when it does relize it, you will just get a "gascap" on your odometer and then your check engine light will come on shortly there after. aside from that, you're good to go.
Old Mar 16, 2010 | 08:29 PM
  #33
Blonda's Avatar
Default More pics...finally
Since we showed up halfway through the run, most of my pics are of the par-tay!
You can see all the pics here:
http://s7.photobucket.com/albums/y28...Rocked%202010/
Old Mar 20, 2010 | 06:41 PM
  #34
Woulda. Shoulda. But couldn'ta.
So you were all able to do this on one tank of gas?
