37" tires
^ I have to disagree with your comment regarding gears. 3.73 may seem sufficient to you, but I promise you...you don't know what you're missing. My stock gears were drivable with 35's, but they left much to be desired off-road and on hilly roads. Crawl speed absolutely sucked, was constantly riding the clutch, 6th gear didn't exist, and I found myself downshifting more than anything. After gears? 4th gear going 40mph up a hill. I can pass people in 6th gear. 1st gear is very short now, but 6th gear exists again...and I'm getting 18mpg in 6th gear @70mph with 37's and beadlocks. Pretty good.
There's a common misconception that we regear for speed or acceleration, but this doesn't tell the full picture. With bigger tires, especially 37's, it's imperative that you regear in order to take the stress off your transmission/drivetrain. 3.73's and 4.10's will be drivable, but that's about it. Yeah it's a lifted Jeep and it's not meant to go fast, but that doesn't mean you shouldn't regear to the proper ratio if you can afford it.
When it comes to rocks, crawl speed is so important. The absolute best mod you can do to a JK for rock crawling is picking up a Rubi 4:1 tcase. Given that you (OP) already have the 4:1 tcase, pick any gear ratio that will suit your driving needs. I picked 4.56 over 4.88 because I drive my Jeep to the trails and wanted to keep the RPM's down (I usually drive around 80-85) while still having good power. Jeep feels stock now with 4.56 and heavy 37's, but my 2 door is also very weight conscious/light. 4:1 tcase makes it crawl slower than a turtle anyways, so I didn't need or want deeper gears.
If you daily drive and are a slow driver, parking lot queen, mall crawler. There is very little applicable advice to gears unless you like to race. Period. The 37s do not strain the engine/trans combo on a newer JK with the trans coolers. If you live in the Rockies, or the Appalachian area, I can definitely see a benefit to gearing as you climb mountains. Downshifting will become a bear. If you live in the flatlands (most of America) and you don't off-road... keep your 3.73 or 4.10s. In my circle of commuting, my Jeep NEVER has to downshift. And I also never hit 80+mph. And to comment on the trans. straining - I mean, unless I see some FCA case studies that show 37s are prematurely causing trans or engine failures, then I believe most pro's and con's stories are mostly anecdotal. Most people are going to keep their Jeep for what...? 5-6 years? They may lift it, throw 35s or 37s on it... trade it in after set period of time, and never have a transmission or drive train issue at all. At least that is how real world goes. Rarely people keep their vehicles for 20+ years and put 600,000 miles on them. But I will 110% agree, heavy offroading will break something quickly on 37s... geared or not. I mean I know people stock height...thrown 33's on ...and break stuff. That is part of the off-road game period. You will break crap, guaranteed....if you are pushing it. Jeeps, Hummers, FJ Cruisers, etc.... they all break. And alot can be attributed to people not knowing how to drive it offroad as well. But if you heavily off-road, I do believe you are spot on, it will definitely help rock crawling. I think even with an automatic, you will have issues on heavy off-roading without a taller gear, period. I also agree with your Rubi T-case comment. That is one of the best things you can do for rock crawling.
Sorry to digress, OP, it's all up to you. If you know you will be driving it off-road and want to visit Rausch Creek....Mt. Morris.... do some real rock crawling - get you some gears. And BoraBora's list is spot on, period if you plan to utilize your Jeep like a Jeep. But if it's just hauling the family up to the local DQ on the weekends and driving you to work - you may want to skip em.
Just re-geared the 2016 Wrangler to 4.88 w/37" tires. Now it seems as though the transmission shift points are off, no power at all to the wheels it seems. I just ordered the superchips flashcal that i read about in one off these threads...will this fix my issue?
Sorry for the weird posting, waiting on an admin to approve me so had to reply/post on another thread...
The programmer arrives today, I believe the jeep is in reduced power mode, can i use the programmer with it in this mode? Currently waiting on the mechanic to take it out of reduced power mode.
I realize I probably should have had the programmer BEFORE the re-gear but didn't realize it was needed..."facepalm"
You just need to set the gear ratio and tire size in the computer and you'll be set.
I'm surprised after all the post's I went through I never saw the Jscan as an option...too late now I need to drive this thing, leave ends tommorow and I need to get to work lol.
Should I wait until limp mode/reduced power mode/whatever it is be fixed by the mechanic BEFORE I use the programer?
Ok, thanks a ton to all of you guys. I just got the jeep and am learning quickly there is HUGE learning curve, glad there are guys like y'all out here to help us newbies out!
Indeed there is! I suspect you'll be back for some more things along the way since you're rollin on 37s. There's typically a few of us regulars hangin around with quick response. Take some pictures along the way and consider submitting an entry in the featured jeep of the month contest
