Sponsored by:
Sponsored by:
Cooper Discoverer STT Pros vs KM3s
Old 09-21-2020, 07:57 AM
JacobGeha's Avatar
Default Cooper Discoverer STT Pros vs KM3s
I'm just trying to figure out which tire would be best for my 2 door Wrangler. I use it for a daily driver and occasionally off-roading but no rock climbing at all. Mainly dirt, mud, sand, water.
Old 09-21-2020, 08:17 AM
karls10jk's Avatar
Any particular reason you're limiting yourself to those two tires? If you're not mud bogging (or if you have a winch) the BFG KO2's are an awesome tire for dirt, sand, and water. I used mine like that for 50k miles with plenty of tread to spare. I made the switch last year back to Mickey Thompson tires and use the baja boss on my daily driver. I don't know about mileage, but there's a lot of rubber on them 21/32" to start with) and they weigh the same as the KO2. Weight is primarily what kept me away from the KM3.
Old 09-21-2020, 08:19 AM
JacobGeha's Avatar
the look and aggressiveness
Old 09-21-2020, 08:39 AM
karls10jk's Avatar
Dick Cepek Extreme Country may be a good candidate for you then, it looks tough. There's also the sister tire of the Duratrac that's got barbed wire down the side, though I can't recall the name now. Kanati has some tires with beefy sidewalls. I guess what I'm driving at is there are more than just a couple of aggressive looking tires. Just be sure to check the weight of all of your contenders in addition to the tread depth when you're buying.
Old 01-31-2024, 02:20 AM
deaert-car's Avatar
Default Cooper stt failure
Hello,
A 4 years old dated 19/19 stamped on tyres set of the cooper stt pro
on a highway at 50 mph rear left tyre just was falling apart
is this normal?
Can I address the manufacturer ?
Was placed back on vehicle after tyres change
On situ
Quick Reply: Cooper Discoverer STT Pros vs KM3s
