Sponsored by:
Sponsored by:
post your true tire diameters
Old 11-29-2013, 04:46 PM
  #21
pablorg's Avatar
285/70 R17 Maxxis Buckshot Mudders measure 32"
Old 03-13-2014, 02:27 PM
  #22
unlimited12's Avatar
255/80/17 cooper discovery st maxx 35 psi on stock rims measure 32 1/4
Old 03-13-2014, 04:34 PM
  #23
metaldemon's Avatar
I have 255 Rubicon BFG MT. I measure the rolling circumference and divided by PI. This gave me the diameter of 30.75. I programmed my Procal with that number, and the speedometer is right on the money. I checked it with 2 different GPS's.
Old 03-13-2014, 05:09 PM
  #24
jadmt's Avatar
toyo open country at2 285/75-17 28psi on 14 jkur just a hair over 33". stamped on the side is 34"od
Old 03-13-2014, 05:18 PM
  #25
terrabit's Avatar
Originally Posted by Tooadvanced
Measuring to the bottom while parked may be different when park than when in motion though correct? Wouldn't centrifugal force cause the center of the tire to expand thus creating a different radius/diameter? May be thinking of this wrong and or maybe change is so minor that it doesn't matter
Yes, it will. And so will temperature as the tires heat and cool. May not be much but it is quantifiable.
Old 03-13-2014, 05:21 PM
  #26
terrabit's Avatar
This would likely be the most accurate way to calibrate a speedometer but ... for the reasons mentioned by Planman, not an accurate way to measure resting tire height.
Old 03-13-2014, 08:31 PM
  #27
mikestoick's Avatar
315/70/r17 Pro Comp MT/2 Xtremes. 33 1/4 is the actual diameter when mounted and under a normal load.
Old 03-13-2014, 08:36 PM
  #28
JKRescue08's Avatar
315/70/17 Hankook Dynapro MT - 34PSI. 58 degrees measure 34.05
Old 03-15-2014, 11:49 PM
  #29
CAELBLUE1's Avatar
Toyo Open Country MT 285/75/17 @ 28psi = 33.5"
Old 03-16-2014, 01:48 AM
  #30
GJeep's Avatar
35” (315/70/17) Mickey Thompson MTZ
With 30psi for DD - actual diameter 34”.
Quick Reply: post your true tire diameters
