Show your 35's!!!
Old Oct 8, 2013 | 03:49 PM
  #4711
BlackRockBurner's Avatar
Originally Posted by B 1000
My buddy is running 15"s on his 2013. He had to grind down one of his front brake calipers in order to clear them. We also found out that you have to run steel wheels if you want to go with 15"s. Aluminum wheels are made thicker for strength, which make the inner rim smaller; too small for clearance.
You don't have to run steel for 15's: but not all aluminum 15's will fit. I'm running MB72's though they are now discontinued.
Old Oct 8, 2013 | 04:00 PM
  #4712
Patman's Avatar
...you have to run steel wheels if you want to go with 15"s. Aluminum wheels are made thicker for strength, which make the inner rim smaller; too small for clearance.
Not so...
15" Level 8 Trackers (Aluminum) with 35" mtr/k. Teraflex leveling kit and chopped fenders.
Old Oct 8, 2013 | 04:39 PM
  #4713
duongsterr's Avatar
Originally Posted by amick218
I went with the smittybilt oversized tire carrier for $129 with my 35s
hows the tailgate hold up?
Old Oct 8, 2013 | 05:05 PM
  #4714
msavage10's Avatar
Anyone have any issues running 35s on a 2013 JKU Sport S? I have heard mixed reviews in town about needing to re-gear and that the 3.21 can't push 35s. Any advice?
Old Oct 8, 2013 | 05:24 PM
  #4715
Firemedic65's Avatar
Regear. I'm running 3.73 and I'm sluggish as hell. And I have superchips and intake. I can only imagine with 3.21.
Old Oct 8, 2013 | 05:37 PM
  #4716
rcbaker01's Avatar
Our jeeps
Old Oct 8, 2013 | 05:38 PM
  #4717
rcbaker01's Avatar
A better on
Old Oct 8, 2013 | 06:08 PM
  #4718
Vegas-JK's Avatar
KM2's 315/16's
Old Oct 8, 2013 | 07:57 PM
  #4719
Rutgyr's Avatar
Regear if you have the funds, if not go ahead but plan on saving your pennies for a regear as next mod. Around town (anything under 60) its not too bad if you use a procal or equivalent to set shift points. Anything at freeway speeds will drive you nuts quick. The trail will depend on the terrain, its fine where i am being flat but could see it being an issue crawling or going up steep climbs.
Old Oct 8, 2013 | 09:14 PM
  #4720
Warcrimes7's Avatar
My m/t atz. Really good so far, I go through a lot of rocks mud and hills.
