Sponsored by:
Sponsored by:
Tire Clearance/Rubbing
Old 06-21-2018, 04:54 AM
MAG00's Avatar
I'll look into adjusting the arms a little and pulling the inner fenders to get a better look of rubi rails compared to wheel well sheet metal. The other factor that makes the wheel spacing a little different is that I am running Currie VXR60s which are about 2" wider on each side.
Old 06-21-2018, 04:57 AM
MAG00's Avatar
Also, when I looked again yesterday it appears that the rubbing is at the end of the rubi rails. Just seems like even if I trim them flush with the seam it will be close. However, if I've got this right, when you compress the front the travel of the axle will be up and slightly forward not back. So should be fine.
Quick Reply: Tire Clearance/Rubbing
