TPMS Valve stem
Old Feb 2, 2023 | 05:20 AM
paoloeagle's Avatar
Default TPMS Valve stem
Hi, could anyone suggest the best type (rubber or metal) and brand of TPMS valve stem for Jeep Wrangler JK RUBICON 2010 for tyres BF Goodrich LT245/75 R17 All-Terrain T/A M+S 121/118S?
Thank you in advance
Old Feb 2, 2023 | 06:23 AM
ronjenx's Avatar
I had trouble with the OEM metal stems due to corrosion.
The rubber stems have lasted many years. Schrader is the brand I went with. When I bought mine, Amazon had the best price.
Old Feb 2, 2023 | 01:45 PM
Reddout99's Avatar
I am not sure if you have a Discount Tire shop in Italy, but I just use the ones they recommended which are rubber and they are holding up just fine out here in the Midwest of the USA
Old Feb 3, 2023 | 04:53 AM
paoloeagle's Avatar
So, you suggest a valve like this one, with rubber stem:
https://meat-doria.com/it/product_meat/80101
instead of this one, with metal stem:
https://meat-doria.com/it/product_meat/80102
Do you think that the first type is elastic and so better for off road use?
Besides, no problem with corrosion?
Thanks
Old Feb 3, 2023 | 08:51 AM
Reddout99's Avatar
The first one is the type I've always used. In the Midwest they use a lot of salt and chemicals on the roads to prevent icing up. I have not had any problems with corrosion and the rubber ones.
Old Feb 3, 2023 | 10:47 AM
paoloeagle's Avatar
Thank you, I'll buy the valve with rubber stem.
Old Feb 6, 2023 | 09:24 AM
paoloeagle's Avatar
Could you indicate the Schrader item that you used?
The sensor on my JK is Schrader 008CF9B16C 09264 56029359AB.
Old Feb 6, 2023 | 10:23 AM
ronjenx's Avatar
I bought the stem/sensor assembly. I believe it's a different frequency from yours. Part number: Schrader 28308
If you need just the stem, start here and pick one that is appropriate for your wheels. Schrader 20018
