17in slabs do fit. Check out 2XTreme_JKUR Facebook for photos of them. Some of these axles wheel studs are not properly seated causing these to be such a tight fit it may seem not to work
Originally Posted by twinz33
(Post 4232867)
Alright..
The ATX Slabs 17x9 in the 8 lug will clear the rear Spicer UD60 with no problem. I will try the front next once I get it bolted up on the Jeep. Rear: http://i853.photobucket.com/albums/a...psgkxu7nmd.jpg http://i853.photobucket.com/albums/a...psnua6h2hq.jpg http://i853.photobucket.com/albums/a...pshnr4iuoz.jpg |
Originally Posted by Extremneon
(Post 4233950)
Alright.. The ATX Slabs 17x9 in the 8 lug will clear the rear Spicer UD60 with no problem. I will try the front next once I get it bolted up on the Jeep. Rear:
I wouldn't either at this point.
Just wanted to be able to clear up the fact the ATX Slabs will fit. Took a little wiggling, mainly like some had said to get the powder coat off. Pretty easy fit actually. |
Front is bolted on, just a bit of trimming on the drivers side shock mount to finsh up for the coilover.
The ATX Slabs fit just fine on the front Spicer UD60 axle, no issues. |
(Post 4234180)
Front is bolted on, just a bit of trimming on the drivers side shock mount to finsh up for the coilover. The ATX Slabs fit just fine on the front Spicer UD60 axle, no issues.
(Post 4234192)
sounds great! You'll have to post up some photos when it's all finished
Told ya so... lol :)
Originally Posted by RiverCityOffroad
(Post 4234248)
Will post up some picturea when I get it all done. |
