Wheel and tire
Old Mar 16, 2014 | 07:38 AM
rellmatic's Avatar
Default Wheel and tire
If I put a two inch body lift on my stock JK what the biggest wheel I can put, I want to do a 17 inch rim? Rim specs, tire size?
Old Mar 16, 2014 | 07:57 AM
OH9JK's Avatar
JK-Forum Ambassador
2" body lift on a JK is not a great idea. There are better options...
What is your goal? Is there a certain look you are trying to achieve? Off road performance or just for street looks?
Old Mar 16, 2014 | 08:12 AM
MudCHUD's Avatar
with factory wheels a 295-70-17 will slightly rub the front swaybar only on full steering lock
Old Mar 16, 2014 | 05:48 PM
rellmatic's Avatar
Originally Posted by OH9JK
2" body lift on a JK is not a great idea. There are better options... What is your goal? Is there a certain look you are trying to achieve? Off road performance or just for street looks?
Well this is my first jeep, I'm not planning on doing any extreme off-roading or crawling but I def want to have a little fun, i want to throw some black wheels on it with some bigger tires for looks and also for performance. What do u suggest?
Old Mar 17, 2014 | 03:56 PM
OH9JK's Avatar
JK-Forum Ambassador
To answer this we really need to know what size tire you are wanting to run, your budget and your overall expectations.
For example if you are going to run a 33" tire then I would suggest a simple leveling kit. These come in spacer or spring based kits. The spacer kit is going to be less expensive, but the spring kit will give a better ride.
