2 Door Soft Top Strap Fix
5 Attachment(s)
If the nylon webbing straps that run from the middle bar to the back bar look like this:
Attachment 449429 Then this write up might be helpful. You need some 2 inch or 3 inch wide black nylon webbing. I found 25 yards (way too much) of 2 inch wide webbing on amazon. Search: 2 inch 25 YDS Heavy Black Polypro Webbing for $13.95 You also need 3/16 inch aluminum rivets. I used the "short" ones from Lowes. My pop riveter also crapped out halfway through this project so I had to buy one of those too. Rivets: ~$5 Pop Riveter: ~$20 I originally borrowed some stainless steel rivets from work, however I learned that you can use these with a manual riveter. So I had to buy aluminum ones. If you have a pneumatic pop riveter, than you can use the stainless ones. Orient the soft top like this: So you can get to the front and back rivets easily. Attachment 449423 Measure out 37 inches of nylon webbing. I originally started with 39, with the rivets a half inch from the ends, this was too loose, then cut it down to 38, still too loose, but 37 worked. This might be different for every top, I don't know. So measure the other side if it is still good first. Cut and burn both ends. Attachment 449425 I punched some holes for the rivets a half inch from the end with a leather working punch: Attachment 449426 Then it looks like this: Attachment 449427 |
Strap Fix Contd.
4 Attachment(s)
Drill out the old rivets with 3/16 inch drill bit. Add a 3rd hole in between to the center and the right hole:
Attachment 449432 Rivet the strap to the bar: Attachment 449434 Do the same on the front: Attachment 449435 I also did the other side, the orginal strap was still usable, I just added 2 more rivets: Attachment 449433 Done! Top fixed. We will see how this holds up. This is my first write up, so let me know what you think. |
Yup! My drivers side looks like that! I was wondering how to fix it! Thanks, I'll have to try that! :thumbsup:
Originally Posted by barefooterjr
(Post 3526543)
Attachment 449432 Rivet the strap to the bar: Attachment 449434 Do the same on the front: Attachment 449435 I also did the other side, the orginal strap was still usable, I just added 2 more rivets: Attachment 449433 Done! Top fixed. We will see how this holds up. This is my first write up, so let me know what you think. Did you use a lighter to melt the ends of the strap before installing? To keep it from fraying? Let me know! I just ordered all the materials to do this too. Melissa |
Quadratec sells the replacement straps now but I had a similar issue and ended up parting out the top.
As far as melting the ends- I would have to say yes. You don't want them unravelling. I'd punch holes for the rivets with a hot nail to melt those too. |
