2 Door Soft Top Strap Fix
Old 04-21-2013, 11:13 AM
barefooterjr's Avatar
Default 2 Door Soft Top Strap Fix
If the nylon webbing straps that run from the middle bar to the back bar look like this:
Then this write up might be helpful.
You need some 2 inch or 3 inch wide black nylon webbing. I found 25 yards (way too much) of 2 inch wide webbing on amazon.
Search: 2 inch 25 YDS Heavy Black Polypro Webbing for $13.95
You also need 3/16 inch aluminum rivets. I used the "short" ones from Lowes. My pop riveter also crapped out halfway through this project so I had to buy one of those too.
Rivets: ~$5
Pop Riveter: ~$20
I originally borrowed some stainless steel rivets from work, however I learned that you can use these with a manual riveter. So I had to buy aluminum ones. If you have a pneumatic pop riveter, than you can use the stainless ones.
Orient the soft top like this:
So you can get to the front and back rivets easily.
Measure out 37 inches of nylon webbing. I originally started with 39, with the rivets a half inch from the ends, this was too loose, then cut it down to 38, still too loose, but 37 worked. This might be different for every top, I don't know. So measure the other side if it is still good first. Cut and burn both ends.
I punched some holes for the rivets a half inch from the end with a leather working punch:
Then it looks like this:
LC Boyer (07-30-2019)
Old 04-21-2013, 11:18 AM
Default Strap Fix Contd.
Drill out the old rivets with 3/16 inch drill bit. Add a 3rd hole in between to the center and the right hole:
Rivet the strap to the bar:
Do the same on the front:
I also did the other side, the orginal strap was still usable, I just added 2 more rivets:
Done! Top fixed. We will see how this holds up.
This is my first write up, so let me know what you think.
Old 04-22-2013, 08:11 AM
CMEvans's Avatar
Yup! My drivers side looks like that! I was wondering how to fix it! Thanks, I'll have to try that!
Old 07-30-2019, 04:20 AM
Melissa Patrice Thomas's Avatar
Attachment 449432
Attachment 449434
Attachment 449435
Attachment 449433
Hey barefooterjr -
Did you use a lighter to melt the ends of the strap before installing? To keep it from fraying?
Let me know! I just ordered all the materials to do this too.
Melissa
Old 07-30-2019, 07:37 AM
karls10jk's Avatar
Quadratec sells the replacement straps now but I had a similar issue and ended up parting out the top.
As far as melting the ends- I would have to say yes. You don't want them unravelling. I'd punch holes for the rivets with a hot nail to melt those too.
Quick Reply: 2 Door Soft Top Strap Fix
