2012 rubi' locker modification
Old Jan 27, 2013 | 10:57 AM
  #21
jkrubcon's Avatar
What is a spod ?
Old Jan 27, 2013 | 10:59 AM
  #22
calys003's Avatar
http://www.4x4spod.com/mobile/default.aspx#C12
Old Jan 27, 2013 | 11:02 AM
  #23
calys003's Avatar
Originally Posted by DROELLE
Nvm why wouldn't it work with the spod? All you need is a 2 position switch
With the spod you wire the positive and negative to the control box and than your done. So maybe just wire the negative to the locker relay and that's it??
Old Jan 27, 2013 | 11:30 PM
  #24
DROELLE's Avatar
Are you trying to just leave the switch out of the equation? No then your locker would locked full time. If saying just just wire the negative in place on the switch? Then yes. There is no positive feed on this mod running to the relay. Yes I was sceptical about this to. But on at test run at the shop, at my work, before hitting the switch I burned out in 2wd on smooth pavement. Sure enough with the switch NOT engaged I got single tire fire. With the it engaged I lit both rear tires up! I went about wiring mine up different though. Ill try to get pics tomorrow.
Old Jul 5, 2018 | 07:12 AM
  #25
Tfishmrt's Avatar
Anyone know if I need to do this if I am replacing rear elocker (2013 Rubicon) with an ARB? Will I have to tap only front relay to be able to turn on front locker without computer seeing the rear is on?
