Advance Adapters Shifter Cable Upgrade Write Up!!!
#31
Scott W,
Ill tell you first hand, this cable and shifter upgrade fixed my issues with the t-case shifter completely.
My bushing broke once on each side of the shifter at different times.
The second time it broke on the shifter side inside the console. My 4wd light was lit constantly until installing this assembly. Within an hour of install and cycling through the t-case, the light went out and has stayed off until it actually is in 4 hi. What a concept.
Need any tips, let me know. I would be glad to help.
#32
Got my cable and installed it. The only issue I ran into was I put the lever that attaches to the T-case on facing the wrong way. This makes it impossible to set the cable length properly. Once I figured out what was going on I had no problems. Shifting the T-case feels smoother than it did before, plus it's nice knowing it won't break on me.
#33
That part had me a little thrown off also. I got lucky on my cable ends, i just centered them and tightened them down. I love having the confidence and full control on the t-case shifter as well.
So many parts in the entire assembly get upgraded, from the lever to the cable. Install is relatively easy if you can get the console out. That's the most time consuming step, at least for me.
#34
Ya, removing the center console is a PITA. Once I unhooked the E-brake cables from the rear wheels I could get the brake handle up high enough to remove the console. Not sure where I read that tip but it was helpful. On my Sahara I didn't have to remove the front driveshaft like the instructions say, that must be a Rubicon thing.
#35
#38
That is the boot I removed and replaced with a thinner rubber sheet.
I used silicon to seal it back to the body. That boot just looks funky anyways. I should have taken pics of doing this, but most people seem interested in dealer fixes. I wouldn't let the dealer near my vehicle if they paid me.
#39
My 4x shift cable broke at the most inopportune time. My wife likes to go for rides, but draws the line when 4lo and lockers will no longer allow unassisted forward progress. When the cheap plastic "designed to break" let go under shifter, I needed to finish the trail in 2hi. Yes, I could have jammed it back into 4hi, maybe even 4lo, but reaching around the hot exhaust pipe was painful enough. I winched through a couple of boulder fields and made the trail no prob, but the wife wasn't appreciating winching anything.
The little plastic clip by the t-case literally disintegrated when I touched it. Engine heat, which is almost as bad as Arizona summers, took its final toll. I got the Advance Adapters shift cable upgrade (always upgrade, never just replace). This thing should be just about bullet-proof. Didn't think it was possible until I tried it, but the boot on the transmission hump fit around the new cable too.
Now, got to get the PowerPlant fixed and the driver's airbag working again. But that's for a different thread.
#40
Seems like it always breaks when you need it to work. Irony is a cold witch.
Same thing happened here, first time around. Here I am almost a year after the upgrade and I couldn't be happier. Cable works every time, no issues at all.
Best upgrade to the jk, period.
