another $30 home CAI
Old Jul 21, 2008 | 02:25 PM
ZoSo-Green's Avatar
Default another $30 home CAI
$26 intake (91-96 for 91-98 Civic) off of ebay.
$5 plactic trash can.
$.97 1/2" pipe insulation.
Just patiently cut and fit, cut and fit, cut and fit ect...
The vacuum line that was included w/ the intake made a perfect
seal for the intake tube. had to tap a hole for the air sensor, but all
in all pretty easy.
Noticeable power increase and sounds awesome.
Old Jul 21, 2008 | 06:14 PM
SASQUATCH's Avatar
Looks great, excellent innovative approach to a $250 vendor made product.
Old Jul 22, 2008 | 03:13 PM
pastorsteve's Avatar
Looks great. But now the real scoop - How's it work? Any felt benefit or problems?
Old Jul 22, 2008 | 04:39 PM
08{GA}RUBICON's Avatar
I wonder if there is the proper amount of air / fuel mixture to actually increase performance! What does it sound like? Sorry but are you running a Jeeponda?
Old Jul 22, 2008 | 11:44 PM
ZoSo-Green's Avatar
It works great and there are no probablems at all.
I cannot give you dyno results, however big brand name CAI’s claim 7-15 hp and
14-25 ft/lbs. My setup definitely falls in that range, but that is not really my concern.
The engine at full throttle now comes alive at 1800rpm and continues to pull through-
out the power band. Driving is a good deal more enjoyable.
In town shifting the 6-speed from light to light is now fun, and interstate / hwy
merging and passing is more effortless. At part throttle you can’t tell it’s there,
but step on it and you get a smooth deep throaty sound.
The intake tube is the same diameter and an inch or two longer than the $250
version, so I, be willing to bet that I am flowing the same amount of “Dyno tested, CNC,
Mandrel-Bent” air as the more expensive ones.
As far as the fuel mixture… pretty sure that’s up to the computer and engine to work out.
The Idea is merely to supply a cooler more dense chagre of unrestricted air to create a
more effective air fuel mixture.
Old Jul 23, 2008 | 03:27 AM
Sounds like it is doing what you need it to, good job!
Old Jul 23, 2008 | 05:50 AM
[N]UGE's Avatar
nice work. big money saver.
Old Jul 23, 2008 | 06:46 AM
Spetz's Avatar
Do you have the tube diameter or actually ebay item number / description of the CAI ?
Old Jul 23, 2008 | 08:30 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Looks good, just stay away from puddles, there were 2 more hydrolocks this past weekend, one in FL and one in CO both with cai.
Looks like you could use a pool noodle instead or pipe insul. to color match jeep
Old Jul 23, 2008 | 09:44 AM
SASQUATCH's Avatar
Air/Fuel is not governed by the air intake at all, PCM controls it.
