Attention all clunky steering people
#101
OK guys never mind.....I got fed up and removed the steering shaft. I pulled down the boot, massaged some fifth wheel grease into the splines, used a hose clamp to secure the upper boot and boom! No more clunk! WhooooooHoooo! Verry happy with the results, it feels like new again. I wonder why they don't fill that boot up with grease from the factory?:
P.S. For anyone who cares to know here is the grease I used....
Delo Greases EP
Chevron Delo Greases EP are technically advanced, extreme pressure greases for on- and off-road applications. Four types of Delo Greases EP are available for use in a range of high- or low-temperature conditions.
Features
• Delo Grease EP NLGI 1 and 2 are recommended for temperature range from -18°C to 177°C (0°F to 350°F); Delo Grease EP NLGI 00 and 0 can be used at temperatures as low as -34°C (-30°F)
• A high dropping point of approximately 266°C (510°F), results in excellent high temperature stability up to 177°C (350°F)
• High performance in unusually demanding conditions of high and low temperatures.
Applications
• On-highway, heavy duty trucks: wheel bearing and chassis applications including steering drag links, king pins, transmission cross shaft spring pins, shackle pins, brake cam shafts, and fifth wheel faceplates and pivots.
• Off-highway vehicles: haul trucks, loaders, tractors, cherry pickers.
• Medium- and light-duty trucks and buses: Class 7 and Class 6 vehicles requiring extreme duty greases
Select Performance Specifications
• Exceeds NLGI Certification Mark GC-LB (NLGI 1 and 2)
• Mack® MG-C grease specification
__________________
Delo Greases EP
Features
Applications
__________________
#103
Its so wierd how it works. When i put the shaft back on it felt the same but no clunk when driving! When I was greasing the shaft and working it in, the shaft did actuate alot smoother though. The hose clamp is the way to go too. It looks profesional! They should have used grease and a removable clamp to begin with.
Go for it it was really easy and totally worth the effort! Let us know how it goes for you....you won't be dissapointed!
Its amazing how these things get figured out on this forum. I would have NEVER found the problem!
#105
I purchased it from a local trucking company. I asked for 5th wheel grease and thats what they gave me (see above). They said its "good stuff" very resistant to heat. I had to call a few places though.
#106
Cheers...let me know how it goes.
Remember not to turn your steering wheel while the shaft is off....very important!
#107
Also when the boot is removed it makes it easier to apply the 5th wheel grease.
I don't like the poke a hole method because once the boot is compromised its always compromised. I don't think it can be replaced.
I'm glad it got rid of your clunk though!
#108
But anyway I'm glad to hear you solved your clunk problem for now. Just some info, If you ever need a new shaft I hear they're not very expensive. I've heard anywhere from $60 - $120.
Take care Shayu!
#110
I still haven't done the greasing so I can't help with that. However, when I loosened the upper u-joint bolt, pulled the shaft up a few mm and retightened, the clunk has gone away about 98% of the time. I've driven about 500+ miles since doing this both on road and wheeling. I'd try doing that too.
