Benchmark evap skid
Old Aug 9, 2009 | 06:11 AM
FinallyJO's Avatar
The combination of the quality of the Benchmark Skid Plate and your excellent write up convinced me that this was the best choice for EVAP protection. Now that I have one, I have one question: how do you remove the sensor plug from the evap unit? Is there a piece that needs to be depressed, or does it just pull straight off? I don't want to damage it. Thanks.
Old Aug 10, 2009 | 05:50 AM
sin52's Avatar
Yup, little clip on the side. then it slides right off.
Old Aug 10, 2009 | 09:41 AM
PIPES2008's Avatar
sorry for not following up on your question-been away for a while!--to answer your clip question, yes. its just a pinch type plug harness, similar to the door wiring harness quick release clips. just pinch, and pull-...(that's what she said!)-sorry, couldnt resist.-good luck!
Old Aug 10, 2009 | 08:07 PM
Soopurman0's Avatar
i must agree.. the skid is awesome and takes a lickin!!
Old Oct 16, 2009 | 10:06 AM
Fathom's Avatar
Mine went on in a flash and looks great (you just have to get under the jeep to see it )
Old Oct 16, 2009 | 11:12 AM
alaskabound's Avatar
I'm happy with mine.....very easy install.
Old Oct 16, 2009 | 10:47 PM
PoorDad's Avatar
Put mine on today. Very simple to do. It took me longer to find my socket than it did to put the skid on. There was a chip at the back side of the skid, but I will be doing worse to it than that, so no biggie. I also put on a set of Daystar hood latches today, too. The whole mod session took me 45 min
Old Jan 22, 2010 | 07:43 PM
schmugboy's Avatar
For those not wishing to take a bunch of wrenches or sockets under to figure out the right size. I used a 16mm to remove and re-install the factory bolts. Good write-up did not take me long laying on my back, thanks for the tip to remove the sensor first and slide it from front to back. Great product even better that everything lined up perfectly.
DD
Old Mar 1, 2010 | 07:01 AM
HG07JKRubi's Avatar
Just added this to my short list along with their new BEEFY oil pan !!!
